Steering shaft 2010 Ford fiesta
Hi
Thanks for having me
My problem clunk noise from steering when driving very slow or in reverse
Am Told  it is wear on upper knuckle joint of steering shaft
Have good idea how to change it
but can not find the torque settings for the 12 mm nut or the 12 torx nut involved
would be very thankfull if somebody can let me know same in N/M
Thanks Martin
Often a regrease will fix this.
Thanks Marky would you recommend removing it to do regrease  job
Hi There,
Did this a couple weeks ago After my complicated work on the steering column try "Ian Lanc" method first
see link. but use Lithium spray grease with thin straw nozzle attached. But you will have to spray upwards into gap
 where upper bigger tube fits over smaller lower tube. Squirt into this joint gap as much as you then clean off
excess and take for a drive, Will take some time for grease to lubricate dry parts leave for a while do driving to
and from normal journeys. If still clunking repeat method above or next method take off only top bolt from steering
column and push down which will compress steering column ( Lock steering wheel in place before removing connection ).
And then you have more room to grease joint gap you can also compress and expand column more easily
https://www.fordownersclub.com/forums/topic/130586-steering-knock-how-to-re-grease-steering-shaft/
Hi Henryge
Good info there thanks for taking the time to reply.If I am reading you right the problem would seem to be in the tubes and not
the knuckle joints as I thought,do you agree
Thank again
Wexyman
Hi There,
Thats right, Above the steering column is electric motor for steering at high speed, This gets quite warm which in turn travels to under greased tube splines and dries up (After a long time Date of manufacture to Date of clunking noise). The knuckle joints are sealed in so if you decide to remove top or bottom connection, If you can move knuckle joint around freely then that ok All issues with clunking noise are steering column tube splines under greased.
   Hope that helps Henry
Henry
great thanks will remove bottom bolt clean and re grease shaft
Will post how it works out
Do you happen to know torque setting for bolt
You are very helpful
Martin
Hi There, No don't know torque settings for both bolts. But used locitie and a resonable tighten up
Used 3/8 sq socket drives size as to not over tighten bolts if you only have 1/2 sq drive set don't tighten
using end of the rachet, Tried searching but got lost in the net (Haynes manual from the library mybe)
           Henry
Hi Henry
Good info got some blue loctite and 3/8 drive ,will keep you posted
Thanks Martin
  • 3 weeks later...
Hi Henryge
Happy new year to you and all.Done that job over Christmas and it worked a treat
thanks again. Due the NCT/MOT IN 2 weeks,while looking the car over discovered the front windshield wash button on the wiper switch not working ,all other functions on switch are working,back wash wipers all ok
any idea’s Thanks
Hi Wexyman
  Happy new year to you to and a great job on fix working in the winter cold.
  • 10 months later...
On 1/6/2022 at 8:35 AM, Wexyman said:
Hi Henryge
any idea’s Thanks
Did you fix that?
I took that stall off (easy to do)
Took the stalk apart (easy to do but watch you don’t lost the little pins with springs attached)
Spray the hell out of everything with electrical cleaner and it will fix your issues
