P2779 intake air system leak.
I have a fault code on my 2015 Ford Fiesta st. It is going into limp mode and I have checked the pipes. Changed the maf sensor and the pcv valve. Any help or push in the right direction would be much appreciated. I’m at a dead end
Spray carb cleaner or WD40 around ALL the inlet joints on the induction system, when the note of the engine changes that's where it's leaking
Check all inlet and boost hoses are intact and not loose first and MAF sensor is seated correctly
