2018 1.0 Ecoboost tyre pressure
The recommended tyre pressure for my 195/55/16 seems a lot less than it should be according to the dash. How accurate is this?
Depends on what it's saying.
Inflate or deflate them to the recommended pressures then reset the system in the vehicle menu.
If your dash information is showing a higher pressure than the recommended pressure shown on the door pillar plate, it could be the tyres are over inflated. You could physically check the tyre pressures with an accurate gauge if you haven't already done so, correct if necessary then reset the system as Mark suggests.
And check pressure when cold.
