pinout continental ems 2102
helle all,
somebody who can help me with a grafic en pinlayout from a fiesta 1,25 2009 ECU continental EMS 2021 S180047001
Pats give a code 16, no crank, after a day of searching   i found there is no can signal  on the Ecu
therefor i need the pinlayout from the ecu so to test i can connect the singnal from the OBD socket tot te right pins on the ecu.
thanks in advance
Anton
all i can say is good luck i have been looking for WEEKS for a pin out on the 1.4 TDCI engine PCM. so far the only chance i can see is to trace each and every wire on each of the looms connected. bit of luck someone will see this and prove me wrong though and have what you need 🙂
