2015 focus front fog lights no power HELP!!!
Hi all
I recently discovered that my front fog lights wasn’t working when I press the button for the lights the display on dash shows that they are on also there is a click from the fuse box like e relay but when I go to the plugs for the lights there is no power there I checked with a multimeter.
fuse is ok any ideas on this thank you
I know you say there is no power there but have you tried changing the lamps, just in case that's the problem?
Do you have "automatic" headlights ?
Does the rear fog light work ?
Hi all sorry for late reply I have changed a bulb for a new one no luck still no power to the connector for the lights when I press the button for the front fog lights the display shows on the dash as on I can also hear the relay working once pressed but still nothing fuse is ok too and yes the rear fog lights work fine only thing I thought is it had a software update from ford and I also know you can change the setting in forscan for front figs so I will check that too
Any ideas
Did you check ?
Not got automatic headlights and yes the rear fog light works
Is there a harness to check for the lights
Have you tried replacing the relay ?
Have you ever seen the front fog lamps work while you have owned the car ?
Does your car have automatic headlights ?
The relay is built in the fuse box
not really know if they ever worked
no automatic headlights
all wires are there and bulbs but nothing
So use FORScan and turn the Fog lights to 'on' there will be a few different options, one for setting them as DRL which will prove if the lights can work.
I have got forscan and out front fog lights to on with no restrictions is that what you mean
