Headlamp failure
Drivers side low beam lamp has aparantly failed, replaced lamp, checked fuses and relays, all apear ok. Any suggestions ?
Hi Ray, well assuming that the replacement lamp was 'good' and not a duff one then I would suggest it's time to get the laptop out and check for any DTC's.
The low beam headlights are controlled via the BCM / GEM unit and so if there is a circuit fault then there is a good chance of a code being stored.
Download FORScan: https://forscan.org/download.html
Example of an ELM327 modified lead that you will also need: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
