P053f cold start
Hi all,
Does any one know what the fuel rail pressure should be when idling on a 1.0 ecoboost?
Mines showing around 3000kpa (430psi) but not sure this is right?
I don't know what you are measuring the pressure with but I'm fairly sure FORScan will have PID's for Desired and Actual pressure for both the high and low pressure sides.
I don't know the exact pressure for your car but 3000 Kpa does seem about right.
Tizer,
Cheers for the reply, I was using FORScan on my laptop so will have to check the PIDs. 3000Kpa just seems abit hi but then I'm not a Ford Mechanic so don't really know.
I've seen some posts suggesting that the P053f relates to the fuel sender not doing its job properly.
1 hour ago, Ajjones325 said:
Tizer,
All should be revealed when you check. There should also be a PID for the Fuel Pump Duty Cycle and I would expect it to be be around 20% most of the time except when you switch the ignition on, when it will be a lot higher.
The code does suggest that pressure is not building up quickly enough when cold and your assumption may be correct but I don't have any more information other than that.
