Rear passenger door
hi
I’m enjoying reading all the topics
On here
i bought a 2018 fiesta
5 door
in November a couple of questions
rear passenger door won’t open from inside
and the oil says it’s only got 36%
i have only done 110 miles
bought from ford evans halshaw wales
they told me to spray wd40 in door
lock hasn’t helped I’m in Scotland
thanks for any advice.
Rear door might have the child lock on, there’s a slot for the key on the edge of the door.
It has 36% oil life, when was the last time it was changed or the gauge reset?
Hi car service book was stamped in November
2021
Look in the manual on how to reset the oil life gauge
Hi I can’t find this slot
do you have to take a small black round
grommet off
rac inspection told ford this
door wasn’t working properly
my skill level is blowing up tyres
2021
For your own peace of mind, as you have only driven just over 100 miles, pull out the dipstick and check the oil level and colour. The oil should be clean, with very little colour. If it’s “Conker brown or darker” it’s not been changed in a while.
Thanks that makes sense
I will do that now
1 hour ago, MarksST said:
Thanks no way I would have found that
i will try tomorrow
much appreciated
I did exactly what you told me
and oil is at correct level
and nice and golden
so much for main dealer
great advice for novice
like me much appreciated
i will try tomorrow
much appreciated
Thanks I found that slot
unfortunately it is still locked
from inside
opens fine from outside
Did the slot turn easily ?
It should rotate 90 degrees from the position it's in now.
Yeah turned freely no resistance
There should have been resistance, so maybe it has become disconnected inside the door.
Try the other rear door so you can make a comparison between them.
Both rear doors feel the same when turning
the child lock
thanks for all replies
looks little a trip to ford evans halshaw
