Throttle problem.
2007 Focus 1.6
  • Off road for 12 months, engine run and car moved occasionally, battery kept requiring a charge.
  • Replaced battery, car OK.
  • Drove car in for MOT, next day garage 1 reported it had gone into limp mode, MOT obtained, garage reported limp mode something to do with wires in footwell .
  • Car OK for a few days.
  • 17 mile trip to shops car went into limp mode. Recovered home.
  • Car showed fault P2176, ‘Throttle position not learned’.
  • Following morning battery flat, had to be winched onto truck to garage 2
  • 2nd garage reported, fault code cleared but new battery defective (Tayna refuse to refund)
    They fitted new battery and car OK for a couple of weeks.
  • 50 mile round trip, car fine, stopped 12 miles from home and car went into limp mode, pulled into garage 1 again and they said switch off and on. Did so and got 100yds. Switched off and on again and drove home OK.
  • Car variably showing P2176, P2108 and P2119.
  • Replaced Throttle body with no improvement.
  • Removed negative battery lead and connected it to positive for a few minutes, reconnected and started engine, ran for around 10 minutes then a further 5, no change. Foot on accelerator resulted if vast increase in revs then a sudden drop off and stall. Showing P2135 code
  • Repeated above procedure with no improvement, engine showing 2 x P2135 and 1 x P2119 faults I can erase all but 1 x P2135. Car still in limp mode.
Help!!!
What do I hit with the hammer next?
