Fiesta V 1.6 TDCi instrument cluster woes
Hi guys, I am new to this forum, so please bear with me, hopefully I'm posting in the correct section.
I have searched for info on the problem with my dad's car, but couldn't find anything useful here. My dad owns a 2007 Fiesta 1.6TDCi which suffered a nasty electrical/electronic failure at the end of October 2021 after a battery failure. There is just no response when turning the key to start the engine, even with a new battery installed, yet all the lights in the cluster were still coming on as usual.
The car has been towed to the local Ford agents, but they didn't have the necessary equipment to analyze the problem. The PCM was removed and sent to Ford in Johannesburg, which I think was a waste of time, since they couldn't do anything with it without having access to the car as well. After the PCM was returned to the local agents, the car was then towed to the Ford agents in Port Elizabeth. The PCM was then replaced, but the engine was still not attempting to start. They then said the cluster was also faulty. Since then an auto electrician has worked on the cluster, which apparently had five faults, of which he managed to fix four. So, no progress since then and in the meantime my parents (both in their 80s) are struggling without their car. And I'm living too far away from them to get actively involved in this myself.
Question I have is: how can a battery failure cause both the PCM and the cluster to fail in a way that the engine simply won't start? With no spare cluster available, what other options do they have? Will a cluster from a petrol model work, even though the RPM indication will be much lower down the scale?
I really hope someone with the right knowledge could shed more light on this. And if someone on this forum, who is based in South Africa, possibly know of a solution to parts availability, it would be great to hear from you.
Hello Dirk,
please repost this in the FIESTA forum and we will try and help you.
https://www.fordownersclub.com/forums/forum/1-ford-fiesta-club/
Thanks, I'll do that, didn't know what the various clubs are about.
