No lights
Help i got a ford fiestaon 2009
It failed mot on no side light back lights fog lights ans not dash lights  they tryed to see whst the problemand was told .? Body controlmodule... but there a upto 6 month waiting..- help
You need to find a "Good" auto-electrician or electrical vehicle technician. This is not a job for a garage mechanic or your cousins, mates sisters, boyfriend.
Yes it does sound like you need the Body Control Module (BCM) replaced. An auto-electrician can probably get you a used/second hand unit and fit it. It will also need to be programmed.
Depending how difficult it gets it might be worth rewiring those lights bypassing the bcm.  If you are lucky it might be a connector plug on the bcm that needs sorting out and not the bcm itself.
I take it they have checked fuse 22 in the engine bay fuse box.
