Rear wiper on a 2006 hatch.
I have checked fuse, which is fine. I have replaced the motor and also the relay which is behind the left hand lining in the boot area. I've also removed the rubber boot where the wires pass through into the tailgate. All wires appear intact. And I have put a meter on the connector at the motor. With the engine running I am getting 14v at one of the connections, nothing at the other. Please help. There are three connections .One is the permanent feed which I assume is for allowing the wiper to rest , and the other is the switch feed for operating the wiper arm. The last connection is earth. I am assuming that I am getting the reading at the permanent feed. Is there anyone out there who can help me. Thank you in anticipation.
