Stop stat
Why does stop start keep stopping
Even after rebooting it
Umpteen variables are required to have it constantly working,winter temperature doesn't help neither does a battery with a low charge.
Could be battery on the low side, battery monitor needing reset. I had to do this today after topping up the battery charge
1: switch ignition on (not engine)
2: ensure headlights are switched on.
3: flash headlights 5 times.
4: press brake pedal 3 times.
5: wait for battery light on dash to start flashing on & off. (can take 30-40 seconds to start flashing)
6: when flashing stops switch ignition off then restart engine. Might take a wee run for stop start to work again
Hth
