focus mk 2 injectors are leaking oil. i changed the copper gasket but now the car does not start
 Hi everyone focus mk 2 enjektörler yağ sızdırıyor. Bakır contayı alıyorum ama şimdi araba çalışmıyor.
After assembling the car, I realized that I replaced the two injectors one by one.
Will this mistake cause the car to not start?
First thing I'll do tomorrow is fix their place. Respects
Do you think my problem is that I put the injectors in the wrong places?
I don’t think it would prevent the car from starting
ty
18 minutes ago, isetta said:
Arabanın çalışmasını engelleyeceğini sanmıyorum
Could air have gotten into the system?
Did you manually bleed the fuel system with a hand pump after changing the injectors?
19 minutes ago, TomsFocus said:
Enjektörleri değiştirdikten sonra yakıt sisteminin havasını manuel olarak bir el pompasıyla mı aldınız?
there were green colored fuel hoses on the side. I vacuumed from that hose
The green pipes are quite a long way from the filter and the fuel pump.  I would think there is air in the system after those now.  The filter itself may even be empty if you've been trying to start it several times.
The problem was solved, one of the injector nuts was breaked down . I also opened a paddy . I unscrewed the nut with a screwdriver and hammer. Doing so loosened the stud that the nut was attached to. Therefore, the necessary fuel pressure was not created and the car was not starting. I tightened the studs and the car worked.
Anyone knowing the torque settings for the two bolts holding the injector on a 1.6 TDCI, 2007 focus Mk2
