Noisy brakes
Ford Focus ST-line 1.5, had the car from new, when I apply the brakes, when travelling slowly in traffic, the front brakes sound like they are scraping, it's not corrosion on the discs, I'm assuming it's normal on a Focus, my previous car never made a noise, unless there was corrosion, I only have 5500 miles on the clock.
Check for a stone/debris trapped between the back plate and the disc...I've had this a couple of times 😉
Probably is slight corrosion esp if you do  short infrequent journeys. Doesn't take much to make a noise.
