One-Touch Windows stops working everytime I open the door
Sometimes the driver side windows doesn't go up with one-touch and I have to reset it. Everything works fine until I open the door and close it again. From that moment on it stops working again, it still goes down with one-touche, but it doesn't go up again. Any idea why this happens?
I don't have wind deflectors or anything else like that
Are you doing it after turning ignition off?
Does Fiesta MK7 even have one touch up?
Try:
Ignition on
One window at a time
Run window all the way down, let go of button
Re-press and hold down button for a further 6 seconds
Run window all the way up, let go of button
Re-press and hold up button for a further 6 seconds
Quote
Yes, because the passenger side has it and works fine.
Quote
Try:
Ignition on
I tried following your steps, but the driver side still loses its configuration as soon as I open the door. What could it be?
Are you opening the door whilst the ignition is off?
Yes, I mean after following the steps you mentioned. Here is what I did:
  • doors closed
  • ignition on
  • I followed the procedure to reset the one-touch
  • ignition off, window works fine
  • I open the door on the driver's side
  • window doesn't go up using one-touch anymore (I have to hold the button to close it). However, strangely it still goes down with one-touch, this never stopped working instead.
How can a problem affect only one direction?
Check connector and cables  at hinge point of door.
