Engine light on
I have an automatic Fiesta titanium ecoboost 1.0 66 plate, so I'm assuming 2017 model. The engine light is illuminated which I know means excessive acceleration or deceleration as its happened before. My local garage attached a diagnostic tool and reset it. Unfortunately my garage is closed for the weekend, is there a way I can reset it myself
You need to find out whats causing it and fix the problem. Just reseting it every time may lead to the problem getting worse and you ending up being stranded one day.
The best way of reading codes is Forscan on a laptop and a modified Elm327 lead (around £30). You have to order the lead online so you won't get it before Monday (unless there is one on prime).
You can try a cheap code reader, but it won't pick up any ford specific codes.
