Gearbox stuck in reverse.
I have a 55 plate mark 2 Focus and today I pulled up at some lights and went to put the car into first gear and the stick felt floppy. I then pulled it back neutral and then back into first but somehow I got reverse gear and it's now stuck in reverse. Nothing will get the gearstick to release from that gear, I had to be lifted home.
Could this be a great linkage or a problem with the box itself?
Can be both but I expect that this problem will be caused by a loose or broken shifter cable.
You should check the shifter cables first. There are 2 shifter cables. check that both cables are still attached at both ends and are not broken. Also check the adjustment mechanism at the gearbox end.
