Front Lower Balljoint
Hi All,
SMAX failed the MOT today on 2 straight forward items, offside front wheel bearing and nearside front lower balljoint.
I can buy the wheel bearing without an issue, however I have questions around the balljoint and arm. The arm and balljoint all appear to be one piece. However in many pictures it shows them as bolt together items. Is the full arm required or can the rivets be drilled and replaced with bolts? I have attached a picture that might explain it better.
You can drill out the rivets and bolt the new one on.  But you'll need a decent drill and sharp bits, the new BJ is likely to be out of alignment with the original, and as the rubber bushes are now 15+ years old (if original), they'll be due for replacement anyway.
Quickest, easiest and 'best practice' is to replace the full arm.  Would only replace the BJ if you're really strapped for cash and don't intend to keep the car much longer.
Thanks @TomsFocus, I agree with you. It seems odd that lots of people only sell the ball joint and not the whole arm.
