Problem with power windows, any way to close manually?
The power window control on my 2008 Focus has gone intermittent, particularly with respect to closing the windows. Sometimes I'll open the window and won't be able to close it later. So far, I've eventually been able to close a stuck window by jiggling the control repeatedly and turning the car off and on (not sure if any of this really helps). But I fear that sooner or later the window will get stuck open, probably when it's raining or when I need to leave the car for a lengthy time.
I'm not seeing any manual control for the windows, and the manual does not mention any. Is there any way to close the windows manually? Any other possible solution?
Since the motors on all windows work fine when activated, I'm guessing the problem is a bad switch or loose connection somewhere.
Nothing you can do manually, only option would be to take the door panel off, unbolt the glass from the clamps, lift it up yourself and wedge it shut with a block of wood.
Does it also play up using the master switch on the driver's door? If so it'll need a new motor probably, if you're getting voltage to the motor. Other possible cause could be broken or damaged wires in the door
It's actually the driver side window that's giving me the most problems. I'm guessing damaged wires or switch, but who knows. The block of wood does not sound like a great solution, sounds like I'll need to take it to the repair shop.
Is the door panel easy to remove? I have a meter and can check if the motor is getting voltage, if I can get to it.
