Prop shaft
I’m confused with this prop shaft on my 89 van it seems to have a hydraulic part at the middle that has failed and make it fall off and can easily be taken off by hand do I get the hydraulic bit fixed or do I need a new one
I'm confused too.  What would the hydraulic part be for?  There is a centre support bearing that might have failed, but I can't think of a hydraulic part.  Don't suppose you've got a picture?
I'm confused three 🤣
Are you talking about the Propshaft support that might look like this picture ?
What is a prop shaft on a van?
Image result for prop shaft on my 89 van
Quote
The drive shaft (also called propeller shaft or prop shaft) is a component of the drive train in a vehicle, with the purpose of delivering torque from the transmission to the differential, which then transmits this torque to the wheels in order to move the vehicle.
