fitting Android double din in a 2008 ghia
Greetings,
I am struggling with swapping my old sat nav unit with a new Atoto android one.
At first, nothing, then bridged the red and yellow out of the quadlock to make both a permenant feed. It looks like there isn't a switched live.
First attempt got power to the unit and it fires up ok. Now the air-con is not working. It has worked intermittantly a few times
I got a canbus attachment, with a  T harness, still no joy.
Any help or advice is greatly appreciated.
Thanks for reading.
  • 4 months later...
Hi did you sort this problem out I have the mk2 2007 version same issue and my red works at 0.56v which is well under the 12.0v it should be and like you had to put constant on my android stereo yellow and red together did you come up with a solution
