Drivers door window and mirror controls not working
Hi.  I have a 2016 smax and the drivers door controls for the electric windows and mirrors have stopped working.
All the windows operate from their own switches on each door and the mirrors adjust when I pick the memory seats numbers (also mounted in the drivers door).  The central locking button works too, just not the whole control panel for the windows and mirrors.
There is 12v reaching one of the 3 wires in the connector.
Any ideas before I buy a new panel?
  • 8 months later...
I have the same problem on my S-max 2014. Did you find a solution?
  • 1 month later...
Today I found the solution for my S-max 2014 with this problem.
In the central fuse box, which is found under the glove compartment, the fuse number 3 "interior lamps" was broken.
I changed it and suddenly the problem with the driver door controls was gone. The interior lamps was functioning even before changing the fuse which made me a bit confused.
But I am very happy that I can operate the windows and mirrors again.
  • 1 year later...
I just had the same problem in my 2012 smax and thank you martin as It was exactly what you said
