Didnt see this coming
Hi James, I'd very much advise against getting that adapter. The USB socket is only at 5V and 2A max. The little converter has to step up the voltage back to 12V and will provide less than 1 Amp which is nowhere near enough to run a compressor.
Think you should consider fitting a traditional cigarette socket in the boot for your compressor. Or you could buy a clip on socket like this:
https://www.ebay.co.uk/itm/144097949877?hash=item218ce838b5:g:K0sAAOSw1H1dgzAr&amdata=enc%3AAQAHAAAAsAJONMUshf6tprXBxDPSYJpVUDFV4685ZyICOvcNO0nj9N5%2B8e809%2Ba3ZgK7YLomVQ3LW4zO3GVVGurwfFgdGrK59N2tqYLMeberbgdQ484MvwJaCfsy8D3ZSTmzb%2BeQiHHeDJC6anwKQ4Qmn%2BHUhOqEpAh1lYMkfZ9UzR4ulB3ooY2XE5WuXPme1RWvvmbRj9q5sLt9i4EQmMrTKCk%2BHD%2B8qccXFcJVbs93XnywzJfs|tkp%3ABk9SR_KXt-7dYA
Cheers for that Uno, will go with the boot idea or back passenger bit of the centre console.
Access to the + battery terminal is a bit tight as it kinda goes under the scuttle panel
