Bleed Ford focus 2001 cooling system
Hi folks. What is the right way to bleed or burb Ford focus 1.6 2001 cooing system? The car hits normal temp in no time both fans come on really loud and the the temp shoots up like crazy in a sec or two hits max. I have replaced thermostat! Temp sensor! Inside the car hitter works fine blowing really hot air. But there is no circulation. Radiator and hoses remain cold.
When was the water pump last replaced ?
It is due (overdue) to have the timing belt replaced for what should be the second time. Get the belt and water pump replaced at the same time.
As unofix says, or the head gasket has gone
