Fiesta 05 P2176 and P0036 errors
Indeed, also removed the need for a manual choke
Oh I remember. A father of a friend of mine used to have an old car that thing was used in the winter or in some different situations. That's around 18 years ago...  I'm getting old lol.
Opened, connectors are clean. If the fail come back again on dashboard , I will try to reset it with forsscan, unplug the battery after that. Maybe that will work.
Problem fixed. At least for now.
Today I received a hose the one that goes from the front of grille to filter body.(most pointed me of missing part so I bought one) When I was replacing that one I took out filter case to check if my local hardware store have a screw because it's missing like 3 screws out of 12 btw a pain when you change air filter. After I reassembled everything. I try to start the engine... EAC fail again. So I haven't touch any wire from the Throttle. But that one from the H2O sensor it's quite easy to touch it right where connector is especially when you replace air filter. Opened that connector and it needed a  clean it was white on some pins.
Somehow that sensor it's communicating with throttle by a wire I think.
I got rid of p0036 and I remained only with throttle body fail.  Odd but mystery is solved.
I turn on my ignition off on and off again.
Then I moved a bit the throttle plate, ignition on off and on off again.
Moved again throttle plate but this time slighter. Ignition on and EAC went poof.
Connected foresscan and all errors are gone.
Just have to replace battery on some day it's only 11.7 on forscan before night. Might be normal I do no.
My radio is gone because of disconnected battery I need the code to make it work again. But I'm thinking to upgrade to some modern one that have a Bluetooth connectivity with phone. If anyone can point me out one that would be nice. I saw some kit on YT but the radio it's not for my needs.
