Ford Etis/Performance pack
I spoke to Ford regarding getting some spec information on an St-3 but they told me due to data protection they couldn't tell me 😕
I have seen Ford Etis mentioned quite a few times but when I went to sign up and use it I couldn't. Is there an alternative?
If a car has the launch control does that mean it has the performance pack with the other extras or can you have the launch control on its own?
if you have the ford performance option for the screen between the dials that gives you a launch control button, they you'll have the performance pack. If you post your VIN then I can give you the full build options list.
VIN is WF0JXXGAHJKU00781
Minor Features
  •  Less Roof Line Conversion
  •  Less Rear Mudflaps
  •  Front Door Scuff Plate - ST
  •  Accesry USB 2 Unit W/iPod Function
  •  Less Interior Pack
  •  Less Front Mudflaps
  •  With Hill Launch Assist
  •  Less Bulkhead
  •  Less Special Purpose Vehicle
  •  Niehl Plant Built
  •  Less Special Equipment Package
  •  Less Terrain Package
  •  Less Marketing Flex Prep Pack
  •  Exclusive Pack 7
  •  ST Sales Badge
  •  Less Special Order Paint
  •  Less SVO Application/Label
  •  Marketing Level 1
  •  With Visibility Pack
  •  (-) SVP
  •  Less SIP
  •  Exterior Paint - Solid
  •  Less Carline Badges
  •  Less Cooling Pack
  •  For Normal Temperature Zones
  •  Less SVO Except Packs
  •  Less Tailgate Badges
  •  Kit - Enhanced Tyre Repair SVC
  •  Sunvisors Sngl Ill W/Cvrd Van Mrror
  •  With Auto Closing Windows
  •  Power Front Windows One Touch Up/Do
  •  Power Rear Window One Shot Up/Down
  •  With Light Tint/Dark Tinted Glass
  •  Window Pack 8
  •  Grille-Upper Painted
  •  Acoustic Laminated Windscreen
  •  With Heated Windscreen
  •  Less Console Ashtray
  •  With High Level Instrument Panel
  •  With High Series Overhead Console
  •  Full Floor Console With Armrest
  •  Front Floor Mats- Deluxe Carpet
  •  Rear Floor Mats - Deluxe Carpet
  •  With Sports Dark Headlining
  •  With Level 3 Door Trim Panel
  •  Less Rear Seat Ash Tray
  •  Less Load Rest
  •  With Load Area Cover
  •  First Aid Retain Strap
  •  With W/Triangle. Retainer Straps
  •  Rear Door Trim Panel - Vinyl 2
  •  Less Active Grilleshutter
  •  Less Roof Rack
  •  Rocker Panel Moulding - Body Colour
  •  Less Exterior Door Frame Mouldings
  •  Door Edge Guards
  •  With Large Single Wing Rear Spoiler
  •  With Electrochromic R/View Mirror
  •  Dual Pwr Heat Mirr Pl Fl Gl Drv+Pas
  •  With Body Coloured Exterior Mirror
  •  With Driver Seat Back Map Pocket
  •  Passenger Seat Back Map Pocket
  •  With Fixed Front Passenger Seat
  •  Less Driver Tipping/Slide Seat
  •  Less Drivers Seat Armrest
  •  With Front 2 Way Headrest
  •  With Fixed Rear Seat Cushion
  •  With Split Fold-Down Rear Seat
  •  With 2 Way Adjustable Rear Headrest
  •  With Rear Center Head Restraint
  •  With Drivers Manual Lumbar Support
  •  With Passengers Man Lumbar Support
  •  With Drivers Heated Seat
  •  With Heated Passenger Seat
  •  Belt Minder-Dr/Pass/2nd Row/Eu T&S
  •  With 2nd Row Folding Seat
  •  With Driver 4 Way Mnl.Seat Adjuster
  •  With Pass 4 Way Manual Seat Adjust
  •  Less Trailer Coupling
  •  Less Towing Pre-Pack
  •  Engine Performance Level-Standard
  •  Less Device Dock
  •  With Soft Feel Gear Shift Knob
  •  Leather Gear Shift Boot
  •  With Child Proof Safety Lock
  •  With Door Dead Locks
  •  Keyfree System
  •  Keyless Entry/Start - Passive
  •  With Trans Linked Rr Washer/Wiper
  •  With Automatic Windscreen Wiper
  •  Less Heated Washer Jet
  •  With Body Coloured Roof
  •  Front Bumper-B/Col Plastic + Grille
  •  Rr Bumper-B/Col Plastic + Grille
  •  Less Front License Plate Bracket
  •  Rear Bumper Beam
  •  Restrain Device Pack 2
  •  Air Curtain Restraint LH
  •  Air Curtain Restraint RH
  •  Less Rear Side Air Bag Restraint
  •  Less Inflatable Knee Bolster Driver
  •  Rr St Belts-2nd Row Acitve Outboard
  •  With Driver Air Bag
  •  With Passenger Air Bag
  •  With Side Air Bag - Drivers Side
  •  With Side Air Bag - Passenger Side
  •  With Passenger Air Bag Deactivation
  •  With Isofix Hard Point Attachment
  •  With Manual Adjust Frt.S.Belt Mount
  •  Style 1 Tether Anchorage Restraint
  •  Seat Belt Pretensioners Drv/Pass
  •  Less Spare Wheel
  •  Tyre Pressure Sensors - 433 MHZ
  •  18" X 7.5" Cast Alum Machined Wheel
  •  205/40R18 W
  •  Less Spare Tyre
  •  With Black Wheel Hub Caps
  •  Less Hub Covers
  •  Locking Wheel Nuts
  •  With Standard Tread - Any Vendor
  •  Components Unique For Alloy Wheels
  •  Less MPH Engine Governor
  •  Starter - Stop/Start System
  •  Starter/Clutch Pedal Interlock
  •  Euro 6.2 Emissions
  •  Special Suspension
  •  With Dual Chrome Exhaust Extension
  •  Hand Brake Cover-Black
  •  With 4 Wheel Disc-Brake
  •  Brake Calipers - Red
  •  Less Collision Mitigation System
  •  With IVD/Traction Control/ABS
  •  Less Manual Shift Auto Trans
  •  With Premium Front Seats
  •  Pollen/Carbon Filter
  •  With Recirculating Heater
  •  A/C Refrigerant-HF01234YF
  •  For Unleaded Fuel
  •  With 95 Octane Level Petrol
  •  Fuel Tank Fill Neck-With Inhibiter
  •  Unique Met Finish Foot Pedals Pads
  •  With Manual Tilt/Slide Stg Column
  •  Leather Wheel With Red Stitching
  •  With Heated Steering Wheel
  •  Less Electronic Speed Limitation
  •  Speed Control And ASLD
  •  Less Auxiliary Heater
  •  With High Series Cluster
  •  With MPH/KMH Speedometer
  •  With Trip Computer
  •  Dual Note Electric Horn
  •  Tyre Inflation Monitor Lvl II
  •  MFD TFT Touch Screen
  •  With Navigation System
  •  Emergency Assistance
  •  Lane Departure Warning System
  •  Driver Impairment Monitor
  •  Less Speed Audible Warning Device
  •  Less Blind Spot Information System
  •  Lane Keeping Aid
  •  Speed Sign Recognition
  •  Thatcham Catergory 1 Alarm System
  •  With Rear Parking Aid
  •  Less Front Parking Aid
  •  Less Automated Parking System
  •  Less Auxiliary Compact Disc Player
  •  ICE - Mid Audio Branded +DAB +TMC
  •  ICE Feature Pack 11
  •  ICP - Mini Electronic Finish Panel
  •  With 10 High Series Radio Speakers
  •  With Radio Subwoofer
  •  Cellphone Interface Passport 4G
  •  Sync III
  •  Less Wireless Charging
  •  With Steering Wheel Radio Controls
  •  Less Smokers Package
  •  Less Cigar Lighter
  •  With Power Point Plug
  •  Rear View Camera-Fixed
  •  Less Specialty Packages
  •  With Black Fog Lamp Bezel
  •  With Level 3 Headlamps
  •  DTRL Lamp Lit In Pos 0 And Pos
  •  With Front Fog Lamps No.2
  •  With Cornering Lamp
  •  Interior Lighting-Ambient LED
  •  Header Mounted Courtesy/Maplights
  •  Tail lamps - LED Rear
  •  With High Mounted Stop Lamp
  •  With Puddle Lamps
  •  With Front Headlamp Levelling
  •  With Auto High Lamp Headlamp
If a car has the full performance pack it will say "Engine Performance Level-High" going off my own ST-3 which does have the PP, so in theory yours does not, but i've never known one to have launch control but not be part of the performance pack. Maybe someone else can shed some light on this?
Hi, thank you very much for the information, really appreciate that. The car is a 2020 plate but built in 2019, I think that's were the confusion has been as it was advertised as having certain extras I don't think were standard until the 2020 builds. There is another car I was looking at but I only have the reg not the VIN for that so not sure if the information is available with just the reg. Would you be able to check that also? I apologise if I'm being rather cheeky by asking you to help further, thanks.
Ford etis does also tend to work off the reg. Thats how i got the spec of the st-3 i am getting at the weekend. The one i am getting is a 69 plate, but build date is very late 2019, so it has the 2020 spec with PP and B&O, and led projector lights as standard. Cars around this age are very hard to work out what they have, due to the spec sheet always changing.
Yeah the ST-3 I am looking at is a 20 plate but built october 2019. The dealership have told me it's 2020 spec with PP and B&O, and led projector lights as standard. But going from what Tom kindly posted it would seem that isn't correct. I will have to get onto the dealership and get them to confirm this before I travel 100 miles. I tried to use Ford Etis but it I couldn't get it to work as a member of the public rather than a dealer/trade etc. Unless there's a way around that?
It seems to me Ford ETIS is being merged into one of fords other systems for dealers and trade operators. I'm niter, but managed to get an account about a year ago, so i can access the information before buying my own. It seems making an account isn't possible now, not in the same way i was able to.
If as you say the car was built in one of the many transition periods between 2019 and 2020 specs that may be where the dealership have got confused. Although, they should have access to this same information ETIS provides, it's unlikely this information is wrong as it must pull from some ford database.
I can try the reg of the other car if you'd like, as i say checking my own ST-3 knowing for a fact what it has, my car shows on ETIS correctly with all packs and extras stated, i've just checked again as i don't want to misinform you, i can only go off what it says. Maybe worth asking on the fiestastoc forum in the MK8 section, you'll get a reply pretty quick, maybe someone else has some other insight.
Hi, thanks for your reply. I have had an email from the dealership today to say that the listing on the website contained auto generated information and that the car doesn't actually have the performance pack etc. Bit of a shame but at least I'm getting my deposit back without any hassle so that's the main thing.
The reg on the other vehicle is CK69 RGV, it doesn't have the performance pack listed on the extras part of the advert but it does have that and the B&O system listed on another part of the listing so it's a little confusing. It may well be they have used auto geenerated info/spec as the previous dealer did, which is a bit of a pain. Thanks in advance, much appreciated.
Sorry for the late reply, while i can find that on eits, the platform itself is being decommissioned by ford so while it'll give me the VIN for that car, it now wont show any information. It links to a new site, so ill have to see if i can get that now.
Ok, thanks for your help.
  • 11 months later...
Hello can someone kindly check mine thanks for the help ford fiesta st-2 (2018)
have the reg and vin
CF18 HJE
WFOFXXGAHFJU14336
  • 1 year later...
On 9/27/2022 at 7:03 PM, Tom44 said:
Minor Features
  •  Less Bulkhead
  •  Niehl Plant Built
  •  Exclusive Pack 7
  •  ST Sales badge
  •  Marketing Level 1
  •  (-) SVP
  •  Less SIP
  •  Less Cooling Pack
  •  Window Pack 8
  •  Rear Floor mats - Deluxe Carpet
  •  Less Load Rest
  •  Less roof rack
  •  Door Edge Guards
  •  Less Device Dock
  •  Keyfree System
  •  With Automatic Windscreen wiper
  •  Rear Bumper Beam
  •  Less Spare Wheel
  •  205/40R18 W
  •  Less Spare Tyre
  •  Less Hub Covers
  •  For Unleaded Fuel
  •  Lane Keeping Aid
  •  Sync III
  •  With Puddle Lamps
, Hello all , can someone do a check for me on an ST3 fiesta , 2019 plate please, as I'm wanting to know for definite if the car has performance pack from factory, cheers
The Ford ETIS site closed last year and was decommissioned. There is no replacement for the general public, only a new site for Ford dealers.
There is a guy on the Fiesta ST owners club site who seems to have access to the info. You could join up there if not already a member.
PP became standard on an ST3 from late 2019, so would have been an option if fitted to a 19 plate.
I would comment that the diff can be a mixed blessing depending on how good/bad your local roads are. On the plus side, traction out of bends is terrific. On the minus side, on rutted, potholed, broken roads (which I am blessed with) it can be an effort to keep it in a straight line when giving it plenty. As I often find myself doing overtakes on narrow Dales roads with a large tractor to my left and a stone wall to my right, this can be "interesting".😀
I have read that the "launch control" feature can be activated using Forscan on a non-PP car.
