Ford Focus 2018 - Scraping noise after Ball Joint Arm Replacement
Hi, hope someone can give me a steer if possible. Following a service it was recommended to me that a ball joint arm needed replacing. The work was carried out and now I am getting intermittent scraping or catching noise when I turn the steering right (not the arm replaced was the passenger side) when the car is moving.
Any thoughts at all? Appreciate it
There's a brake disk shield behind the disk sometimes gets bent when renewing the arms just bend it back hope this helps
