MK4.5 - Autolock enabled IPC but nothing in menu
Hello,
I've got the new Ford Focus MK4.5, I've enabled Autolock in the IPC using Forscan.
I cannot seem to find this as a menu item in vechile settings. I'm wondering if it's not the IPC anymore as vechile settings are displayed on the sync 4 screen instead.
Have you enabled Auto Lock in the Body Control Module ?
You need to do both the BCM and the IPC on the Mk4 Focus
I have yes
BdyCM: Change Auto Lock - Vechile to enabled.
BdyCM: Change Auto Lock - Intial Value to enabled.
Have checked to see if there is anything in the APIM for the locking if the menu has been moved to the SYNC4 screen?
No not yet, I'm cautious when using Forscan didn't want to experiment yet. Thought I'd ask if anyone else with Sync 4 had this issue or determined its an APIM setting now.
Yep it was the APIM setting
So for Sync 4 where vechile settings now lives you need to modify the following
Module: APIM
Entry: Auto Lock Control Function
Value: Enabled
