CC3 window problems
Hi
does anybody Know if a focus CC3 window motor is the same as a normal focus motor .
The motor for the door window is the same, the window control is not the same.
Thank you Unofix that makes sense
I wonder if any year focus motor will fit
assuming I can change the
motor without the regulator
As long as it's from the same model series like Mk2 it should be OK. I don't know but the motor for a 3 door model may be different to that of a 5 door just because of the size of the window. I expect they probably are the same but it would be worth checking if all you could get was a 5 door motor.
