Mk2 2010 Focus Tdci Duratorq P0237 fault code
Hi Guys, looking for a a bit of advice on fault code P0237.
It’s telling me the turbo boost sensor A circuit is low so assuming the sensor is goosed 🤞🏻 but does anyone know where the hell it actually is?!
I also noticed a slight puffing noise coming from one of the injectors which was the injector seal, just waiting for a cutting tool to come as the seat looks a bit pitted so will get that cleaned up before refitting.
 Anyway, any help on the sensor location would be much appreciated!
Which engine size?
As you mentioned injector leak I assume it's a 1.6?  If so, the boost (MAP) sensor is on the throttle body, top left of the engine as you look at it.  It's a 'flat' sensor with one single screw fixing.
Sorry yeah it’s the 1.6, 80KW.
Perfect thanks, I was looking at them but trying to find info on the t’internet was near impossible. That’ll be the job tomorrow.
At least I managed to get the old injector out today after chiselling off the baked on carbon and squirting some Kroil in, if nobody has heard of this stuff before it’s amazing….
  • 1 year later...
I'm having the same engine code P0237 on a focus MK2, any joy with finding the problem?
Regards
Keith
