Forscan using a laptop with Windows Vista Premium
I know lots of members use Forscan but can any one confirm it will work on a laptop with Windows Vista Premium? As this is my only option.  Also will I need to load a driver for the adaptor I use ( I have not ordered one).  I need to checkout my Focus ABS, Traction Control as lights are both on, suspect a  faulty wheel speed sensor.
Thanks any  advice appreciated.  Richard.
  • Supported platforms:
  • Windows 2000/XP/Vista/7/8/8.1/10 (ELM327-compatible adapters with COM, USB, Bluetooth and WiFi interfaces, J2534 PassThru adapters). Note: only x86/x64 architecture is supported for Windows. ARM architecture is not supported!
https://forscan.org/home.html
Alex,
Thanks for the info much appreciated. I'll order an adapter.
Richard
Alex,
Richard
Unofix
I have just ordered £29.99 free delivery from Amazon. 👍
1 hour ago, ford2188 said:
Hi, Unofix, can I buy the cable for my ford fusion 2010? Thanks
Yes it should be fine for your 2010 Fusion. There is an alternative cable which is slightly cheaper which is also suitable for your car.
ELM327(modified): https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
Many thanks - Unofix
