Sensor Ho2S problem
Sensor showing fault for 4th time in 6 months. (BANK 1,Sensor2) Ford parts used. Full diagnosis can't  find another
fault. 1L Ecoboost. Any ideas?
Well if we accept the correct sensor has been replaced each time, and it has been replaced with the correct type, then I would be looking at the wiring. Check any connectors for signs of corrosion or poor contacts causing a high resistance.
P2196:00-AF O2 sensor signal biase/stuck rich - Bank 1 , sensor 1
is this your fault as well?
https://www.fordownersclub.com/forums/topic/9596-ford-fault-codes-the-full-list/page/3/#comments
