2007 focus mk2 1.4 no power
Hello i have a 1.4 petrol ford focus mk2 2007 180000km
Start and drive with no fault on ecu... But have no power at all and have lots of fuel consumption spark plugs full of carbon. Did a Full service and catalytic delete. Clean the fuel pump change oxygen sensor before the catalytic... Clean the throttle but still the same problem no power. There is no smoke on the exhaust engine running smoothly... Any idea? Need help please
Hi DtcFixer
Thank you for your reply and idea. But I did all of it no luck...
The funny thing is im not getting any faults...
Check fuel pump (removed and clean), there is no fuel filter.
Check for vacuum leak...
Check for air intake did a full service...
Check the exhaust system such as catalytic converter did a delete.
There is no maf sensor but Map sensor removed and clean...
Still having same problem...
First gear to second and third I have to go over 2500 rev to change gear if I'm taking over car in front of me
Has it lost power during your ownership or have you only recently acquired it?
They 1.4 isn't really powerful enough for the heavy Mk2 Focus, especially for overtaking.  This also makes the fuel economy poor as you're always on the throttle trying to maintain speed.
Very few were sold in the UK although I know they were more common in other countries, particularly those with tax based on engine size.
Spark plugs full of carbon usually indicates excessive over fuelling and would lead to high fuel consumption.  If fitted with a post cat hego sensor now I assume is missing with the cat ,would require ecu modification.
Have the diagnostic codes been read through the obd socket ?.
Hi just bought the car 2 weeks ago.
But its really down of power. I don't think it's normal because of the excessive fuel consumption and spark plugs getting lots of carbon..
Hi yes I did a diagnostic code but it's no fault on the ecu.. But it was one fault before i bought the car i clear it and change the oxygen sensor the fault never come back.. received_855132409154163.thumb.jpeg.0420fe67953e31c4c1a8993c1e33caf9.jpeg
Hello ford lovers... Still same here did some research but no joy... If someone have some ideas please...
1.no power at all
2.loads of fuel consumption
3.spark plugs full of carbon
4.i did change the oxygen sensor bank 1 (before the Catalytic)
I bought the car few weeks ago.The car start and drive perfectly. I did check the timing mark all ok.
I check if any vacuum leak from the inlet manifold all ok
I check any leak on the exhaust system before the oxygen sensor all ok
Please need some help.
What's your 0 to 60mph time? Should be around 14.1 seconds.
32.5/52.3/42.8 UK MPG urban/extra-urban/combined
75 PS (55 kW; 74 hp), 124 N⋅m (91 lb⋅ft)!!! No power house!!
  • 3 weeks later...
Hi ford lovers. Some update about the 1.4 petrol mk2 ford focus 2007 with lack of power... I find a performance box connected to the ecu, I did remove it. It solved the problem with fuel consumption and carbon on the spark plugs. But still having same problem lack of power... Its seriously no good performance... Specially up the hill have to put second gear or even first gear.... If I'm overtaking i have to put third gear...
If you take off on first gear you have to go over 3000 rev to put second gear and third gear...
Have you checked the fuel injector performance?
They may be clogged or weeping, there are some videos on youtube of how to clean injectors
It could also be that it heavily coked up, due to the mileage.
Valve springs could be weak due to mileage
Has the oil been changed recently?
Has it got the correct oil in?
You done a 0 to 60 test yet?
I did a full service recently. Fuel injector clean too.
Sorry not yet. But I know it won't make it 14.1
....... minutes, hours, or days ? 🤣
It's probably totally worn out then
And finally, have you checked for binding brakes??
