Drivers heated seat not working
2013 Focus 2.0 Titanium x drivers side heated seat not working. Back and squab both no heat. On the  rotary heat switch the seat icon is illuminated red. The passenger side is is illuminated white. Fuse is ok. All the plugs under the seat look ok. Any ideas?
The fastest way to find out whats wrong is to plug in to the OBDII port and use FORScan and check the DTC's.
FORScan: https://forscan.org/download.html
ELM327(modified) cable: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
