scanners
could anyone tell me what hand scanner would tell me fault codes on my ford focus cc3 09 petrol please?
Cannot be to dear.
many thanks
My last post should have included roof codes,sorry
Hi I did purchase the ch340 cable downloaded forscan purchased a new laptop battery but when I connected to the car I could not get any internet connection, thats how it stands at the moment
No need for an internet connection in the car.
Is the laptop able to 'see' the cable?  If not, drivers may need to be downloaded.
I'm not familiar with the ch340 cable but it a known issue that many cables will not communicate either properly or fully with the car and FORScan. The only two cables that are known to work fully are those I posted the links above to.
The ELM327(modified) from tunnelrat electronics was the only cable of that type that was known to always work. Others may work but their reliability is unknown.
Generic handheld code readers are almost certainly not going to read all of the Ford specific DTC's. Even very expensive generic DTC readers often fail to get the Ford specific codes.
Hi
many thanks for your quick reply I will look up the other cable you have suggested and see what happens.
Thank you for taking the time to reply
Not sure I will have another look tomorrow, how will I know what drivers are required please.
Thank you for your help
Usually there's a link to drivers on the site where you bought the cable.
I'm not familiar with this particular cable but a quick Google has given me this for CH340.
https://sparks.gogo.co.nz/ch340.html
tried downloading the link, started too install then failed after quite some time , then said clos server and restart which I have done but still no joy,maybe i'm doing something wrong  but try again and let you how i get on ,
thanks again for your help
Danny
What version of Windows are you running on your laptop ?
windows 10
Hi tried again to activate forscan still no luck ,will now wait till i see a relative who is very good at this of problem,I hope?
It should work on windows 10 without a problem.
many thanks , I think I'm the problem
I will get there in the end
