Potential Clutch wear?
Hello everyone, I have a 2009 focus 1,6 petrol zetec s, I can pull off fine in 1st gear and the clutch works perfectly fine on hill starts etc, however if i put my foot down too fast, no matter what gear or speed the car revs fly up and the car doesn't speed up. As if the clutch was stuck on? I can use the throttle very very slowly and gently and the car builds speed. This making it very difficult to join the motorway or pull off at any sort of speed? Could this be the clutch potentially or anything else anyone could think of? The car also has no wheel weights on either wheel and the tracking is out so car does pull to one side quite heavily... Could this be the issue?? Thanks in advance
If revs increase but the car speed doesn’t, the clutch is slipping.
You can test your clutch by putting it in 4th gear and try to pull away with the handbrake on. If you can get your foot off the clutch without the car stalling then the clutch has gone.
