Identifying faulty injector - using this FordScan data
Regarding a mk2 Focus, 1.8L
Intermittent jerkiness when driving, happens every so often, getting more frequent, little judder. I got the below data from Fordscan. No EML on and no fault codes or pending codes relating to injectors.
The 2000rpm readings below were with the car just idling I revved it to 2000rpm, not actually "driving" at 2000rpm. Is it better to check this driving at 2000rpm?
At Idle:
CLY1 ~ 0.79
CLY2 ~ 1.20
CLY3 ~ 1.29
CLY3 ~ 0.60
 Revving at 2k RPM. now I seem to get a default reading across all 4
CLY1 ~ 1.00007936
CLY2 ~ 1.00007936
CLY3 ~ 1.00007936
CLY3 ~ 1.00007936
This doesn't look right as I would expect some discrepancy between them, any ideas if the 2K RPM reading is faulty?
Thanks for any help you can give.
**No relevant codes appearing
