Ford focus 1.0 ecoboost rough idle
My ford focus st line 1.0 ecoboost seems to be idling roughly obviously the engine is shaking slightly, an also it only revs up to around 4000. Has anyone had this problem before an whats the possible causes of this?
Is  this a new problem ?
Most 1.0 ecoboost seem to idle rough from the many comments posted on the forum.
I know 3 cylinder engines are not so smooth at idling, but it's a rough idle an won't rev over 4000 just shakes when those revs are reached
Is it a Mk3 or Mk4 2018? I’ve been in a few 1.0’s and they all sound wrong at idle you think it’s misfiring 😂
will it pass 4000 when driving? Could just be a soft limiter, does it seem down on power?
It's a mk3 2018 I'll put it on a scanner later even though it dont have any light on, don't think it misfiring as it drives fine not sure if it will pass 4000 when driving I don't really boot it tbh
Just took it for a drive an it does go over 4000 when driven,
Could the rough idle perhaps be the cylinder deactivation function kicking in? My 2022 Focus sometimes idles a little rough (when warm) and I assume it’s because of this.
Cylinder Deactivation does not happen at Idle.
You beat me to it 🤣
I was just about to say that.
OK. Then it was something else I was experiencing. To be precise, it has happened only once for me. Warm engine, below freezing weather. Parked with engine on.
And it doesn’t feel like a lack of power? I’d say it’s probably just a soft limiter
  • 1 year later...
Hi
there is an rev limiter so it will not rev over 4000rpm to protect the engine
This is an old post. One assumes the problem was sorted last year.
You’d hope 😂
Change spark plugs
