Service Engine light, Diesel, after high rpms on highway
Hello folks,
I have a 2017 Focus Estate 1.6 TDCi that will squawk "Service Engine Now" and go into limp mode, sometimes,
- after I've been running at highway speeds for a while
- mostly after a downshift that takes the tach over 4000.  I think once during engine braking in 3rd after I'd been over 4000.
Always on the next startup the warning will disappear.  Reputable local Ford specialist pulled a bunch of random faults mostly related to "loss of electrical connection".  Sent me on my way.  Here's what I've heard:
- someone told me when it first happened that the blue wiring harness connector under the plastic cover near the battery can come loose, causing brief loss of electrical signal
- local shop's guess was that it was under-batteried, and the original battery should be replaced to prevent momentary low voltage events.  But it passed their battery test.
Neither explanation makes sense to me, unless the combination of engine compartment heat and some high-rpm resonance shakes the connector loose.  But it hasn't happened during high-rpm operation at lower speeds in town, no matter how long the car has been running.
I can putter around for months without it happening, but I want to drive it vigourously every now and then without the hassle.  And of course it will happen when I go to sell it, which I'd like to do with a clear conscience.
Anyone else experienced this?
Thanks!
Geoff
Check the BCM (combined computer module and fusebox) located around the passenger footwell / glovebox area for any corrosion on the wiring connector pins.
  • 4 weeks later...
BCM connections clean...
After doing some driving experiments, it seems the Service Engine Now light will come on after any high-rpm engine braking.  Will happen in a lower gear going down steep hill at low speeds, no throttle, just engine braking upward of 4000 rpm, even if there has not been an extended highway run beforehand.
In that driving scenario, there is no fuel being delivered, and absolutely nothing should be happening except mechanical bits moving.... I wish I understood modern Diesel control systems to even guess at what could throw a code.  No fuel = no emissions = no exhaust gas recirculation?
High rpms could mean alternator over-voltage I suppose, which might confuse the electrics.  Hard to believe there's a strange resonance that would interrupt electrics at 4000 rpm.  It doesn't happen during high-rpm upshifting.
Will update if I ever find anything!
You need some Ford specific diags on this.  No point 'guessing' what codes are being thrown.
Do you still have the codes Ford specialist provided?  If not, it would be well worth getting Forscan to read the Ford specific codes yourself.
  • 9 months later...
Did you get this resolved? its happening to me also.
  • 7 months later...
And me!  After a high revs deceleration, warning appeared.  I dismissed it and then it didn't reappear after restart.  Engine had only been ran for 5mins prior to warning so may have still been warming up.  Car is 2017 plate focus estate.
  • 2 months later...
When the engine is restarted the fault goes away and nothing pops up on Forscan.
I seem to have the same problem as the OP and the garage couldn't replicate and find a falt.
It needs to be plugged in to Forscan before switching off the engine in that case.
Use the phone version of FORScan and you can monitor it while the fault is still showing.
  • 1 year later...
I have the same issue with my 2018 Fiesta TDCi ST Line. If I let the revs go over 3.5K~ it throws the spanner warning light and goes into limp mode. Does anyone know what this means?
I linked up the fault code reader and revved the engine until the fault came up. It seems the fault comes up if I lift off at high revs. The Fault code is P1102. A poor reading from the MAF sensor apparently. I'll clean that sensor and see how I get on.
