Nearside DRL not working
Hi can anyone help with this issue please, I have changed bulbs and nothing, can not find any fuse that is for lighting at all! Is there none??
2018 galaxy. If you can help be great 👍 👌
Thanks in advance
Phil
The lighting is fully controlled by the Body Control Module (BCM) and are electronically protected from overload, hence there are no fuses.
Some models do have a fuse for the High Beam (Main Beam) but not for the dipped beam.
Is your model using the High Beam lamp as the DLR ?
Thank you for fast repy,
Ah right, so where do I start to look? Is the BCM under the glove box? Do you have pinouts so I can test please?
Thanks.
Before jumping in to the BCM, which is not a place to visit unless last resort. Does your car have LED's for the DRL's or is it using the High Beam lamp for the DRL ?
Hi it has the H15 bulbs, so the switching high beam type..
Are the high beams working as normal on both sides ?
I know you replaced the lamp, but it is still worth swapping the left and right lamps over encase this is a connector issue.
Hi yes both highs work. I have swapped over the bulbs, same thing. could it be a cable problem? Also u have noticed that the compass has not been working, could it be linked??
Hi well, a strange thing has started, with engine on, only offside DRL is on, but once switch off, the nearside one comes on! So it is working but not at the right time? I have not touched anything with forscan. Can this be changed? Or is it a new BCM??
