!Guide! Rear Crash Bar Replacement - MK7 2011
-Ford Fiesta Zetec JA8  08-13
-Remove the 2 black clips from the bottom side of each rear wheel arch liner (Pull the pins out of the clips)
-Pull the rear wheel arch liner to one side and locate the 10mm bolt for the rear bumper and remove it
-Repeat on the other side
-Remove the 2 plastic clips from under the bumper. It's a 2 stage clip that needs to be separated apart then pulled out.
-Remove the T25 torx screws from below each rear light cluster
-Lay the rear bumper on the ground
-Remove the rear fog light by turning it anti clockwise and pulling it free
-Remove the 4 15mm bolts on the rear crash bar
-Install a new crash bar
-Torque the 15mm crash bar bolts to 20Nm
-Lay the rear bumper back on the ground
-Plug in the rear fog light by pushing it in and turning it clockwise
-Clip the bumper in at either side, starting from the top
-Reinstall the T25 torx screws in below each rear light cluster
-Reinstall the 2 plastic clips from under the bumper. It's a 2 stage clip that needs to be separated apart before reinstalling.
-Reinstall the 10mm bolt either side of the rear bumper and nip it up
-Reinstall the 2 black clips from either side of each rear wheel arch liner (Pull the pins out of the clips before inserting)
Useful sources:
how to remove a 2017 Fiesta St rear bumper...
Mk7 Ford Fiesta Boot Leak Repair & Rear Bumper Removal
