soft breaks
hi i have soft breaks on our mk7, we've replaced both front callipers, replaced break pipes front the rear, replaced both front flexi's, full break fluid change, when the engines switch off the pedals solid, when you start it it breaks to halfway and then travels down to floor slowly, if you clamp the off side front flexi pipe off the breaks are normal with no travel, need help please.  thanks
Sounds like there's still air in the system.  How have you been bleeding it?  Has the ABS pump been service bled through diagnostics?
