horn not working
have checked the horn and have voltage at the horn fuse can hear a clicking noise behind the glove box when i press the horn button but unable to find a relay here, i suspected it could be the clock spring could i be correct
Check the wires/plug that go into the horn unit for breakage/corrosion. Where it's located it's quite exposed and may simply be suffering from old age...
Not the clock spring if the horn relay is operating. toot.gif.e23d80586a3bb9850d1fea7f0c151c84.gif
The fault has to be either a faulty relay or more likely faulty wiring to the horn. As @StephenFord has said the horn is quite exposed and the terminals and wires corrode.
where will the horn relay be, i have looked in the fuse box under the bonnet and behind the glove box and cannot find it . oh one other thing the horn has two pins on the connector is one live and the other earth or both live for the two horns
Edited by vendman
extra info
On a 2013 model the horn relay will be part of the BCM and not user serviceable. Start at the Horns and check the wires and connectors. One positive and one earth.
many thanks for the info, will make it more easier to find the fault, life isnt made easy is it 😂
have applied contact cleaner to the horn and connector terminals and the horn now works, have put silicon gel in the terminal housing to keep out any water that will ingress and cause problems in the future 😃
Now, someone should have suggested checking the wiring 1st, oh, wait a minute LOL
  • 5 months later...
@vendman (or anyone else who can help me) would you mind explaining or uploading a picture of where I can find the horn and connector terminals please? I think I have the same issue as you but obviously I'm not as capable 😅
Give us a clue - do you own a Ford Focus? If so, what year/model is it?? Then you can update your profile so that we'll all know in future..
This is the exact reason that Swiss cows have bells around their necks, because their horns don't work
  • 1 month later...
@StephenFord It is a 2015 Ford Fiesta - sorry took me a while to see the verifications emails etc. but should be on my profile now as well!
This may help in the location of the horn...
  • 1 year later...
Could be the horn needing replacing because of moisture getting to the horn if I replace mine I will ask the mechanic if he can install some sort of shield around it or over it
13 hours ago, bbbbgreene said:
Why do newbies always insist on dragging up old threads which so obviously have been answered? Who drives around (legally) for over a year with a non working horn 🤣
It's Benny from Crossroads 😂
