Cruise Control
Hi
I need advice on Cruise Control, i have a 2014 mk3 diesel 7 seater.
I would like Cruise control being retro fitted, has any one else had this done, or as anyone got any advice.
Mike
It's all down to if the steering column clock spring supports CC wiring
If it does then you will either need to add the switches and wiring harness to your wheel or obtain a 2nd hand wheel with CC fitted, then turn CC on using FORScan
If your clock spring does not support then you will also need the clock spring from a car with CC too
