Galaxy Power Shift sensor issues
Hi All
Can anyone suggest what sensors to check for errors that feed the Power Shift MK2 gearbox?
It has issues pulling away and slowing down, but the actual gearbox is fine, had it checked by several auto box specialists and even refurbished (£3200 wasted).
I suspect a sensor giving it bad info. As when out into reset / learning mode it runs great for an hour, until it auto calibrates itself back to bad.
I changed an ABS sensor, that helped a lot. I've changed MAF and MAP ...but I still suspect the wiring to the MAF... anyone know how to check that?
Any other sensors I should check..
Many thanks
