2013 ST2 - Map lights not working
Has anyone else had this issue. The dome lights come on as they should, on the remote, door open etc. The issue I have is with the map lights. They just wont switch on, also the front dome light sometimes wont work on the button. So can't be a fuse. Is it possible to change the bulbs? It looks sealed to me.
To quote a well used phrase "no user serviceable parts inside"
Having said that, post a few photos of the light unit you have in your vehicle.
Thanks, here's the type of light.
You need a replacement unit. Check out eBay and Scrap Yards.
I had the same problem.
I took the light to bits and its all led's and circuit board so not a lot you can do.
There were some grey ones on E-Bay when I looked, mine was black and rare as anything.
Cost me £50 in the end from Holland.
Good luck.
