Galaxy 2019 Titanium Expensive windscreen wipers
My wipers which spray water onto windscreen needs changing, went to ford garage who would sell me a pair £77.39, a single driver side is £36, I know there are holes to dispense water onto the screen, elsewhere price was £88.
Tried to remove driver wiper pressed the little plastic bit on the side but could not remove the blade any help please.
Modern blade clips are tight within the arm.  Once you've pressed the plastic tab all the way in, it will often take a sharp tug to pull the blade free.  When it does come, it'll go quickly, so make sure you're not going to catch fingers on anything.
Thanks it is now Off, will have to see what Europarts have
Try this company they are normally competitive on price
Wiper Blades (opieoils.co.uk)
Thank you but they only do the rear, but after removing the wiper blade assy, I find that if I can remove the end caps the blade will slide out and ebay will send me a 30" replacement rubber to slide in at a cost of £4.99.
Universal 30" Windscreen Bracketless Wiper Blade Rubber Refill Strip for Car 714998204516 | eBay
I have beaten them, removed the rubber and ordered off Amazon for £6.99  sourcing map Universal 30 Inch Windscreen Bracketless Wiper Blade Rubber Refill Strip for Car : Amazon.co.uk: Automotive
