Stripped hub bolts
Hi I have a s-max 2010 just had my tyre's changed but the garage said I need to change the wheel hub as the bolts are almost stripped they showed me and it's bad. Can I just replace the bolts or do I need to buy a new hub?
You may be able to change the studs by literally just tapping them out with a hammer.
However, Ford only supply them as part of the hub, so you would have to measure the dimensions of yours to order new ones from an aftermarket supplier.
Ok thank you for replying so quick
