P06DD code
I’ve had this issue for the last couple of years since I bought the car, but as it flags up so infrequently, I have only just got around to changing the oil pressure solenoid, which everything points to when you look up the code. The other day I had the same issue going into limp mode on the motorway, and the dreaded P06DD code was back to haunt me. So either the non-genuine (still not cheap) part I used is faulty, or it hasn’t solved the issue and something else is throwing the code up. Any ideas what else it might be?
